What grade?
    What grade?
    Hi gents, having just bought some touch up paint from Paddocks, what grade wet n dry should i use to "flat" it once touched in? Is 1500 grade too course?
    I know nowt about prep n paint!
    Stan
    1500 is OK, but if you have 1200 this is better as 1500 is a little too fine.
    Terry..
      Thanks Terry, i'll have a go next weekend!
      Stan
        hi stan
        as terry said 1200 is better ,use water and rub soap on the wet /dry as you use it this stops it from clogging but be carefully not to rub through then polish with t-cut
        john
