A mate has bought a TR6 a while back and we're trying to get a few of its problems sorted.
Car came from USA and has not been driven except in and out of its garage for about 15 years One cylinder was just not firing and was continuously oiling up. Also a lot of oil was being lost.
Head off, and we discover piston #5 was completely shot. Rings were flapping about in the breeze and piston seemed to be a used one taken from another car where it had previously melted. (all this probably took place about 15 years ago - before Internet and Rimmers so to speak, so use of an old donor engine probably was the best repair which could be affected those many years ago.)
The way ahead for our quick repair seemed clear. New piston duly bought and put into place. Bearing shells and crank seemed OK for a few more miles with very moderate wear pattern. Everything reassembled in correct order with all original parts in the same position as before. Car fired up first time and ran sweet as a bird. 6 cylinders at last.
Mate drives about 70 miles without a hitch. Then something seems to start jamming in the engine because the starter has difficulty turning it over. 20 miles later: massive big end banging.
Just stripped down bottom end down:
Bearing shells and journal on the affected cylinder worn and grooved beyond belief on one side of the journal, leading to over 0.5mm ovality.
New crank is now needed, but we're hesitant to install before knowing why this failure happened so suddenly after fitting a new piston.
Any ideas? What could cause such rapid and catastrophic wear on one journal?
It almost seems like the engine was living with a dormant bearing wear going back to a problem on cylinder #5 which had led originally to the previous ower replacing that piston. It almost seems that with a new perfect piston, the loads placed on the big end by correct compression and ignition pushed this dormant wear over the brink. Am I talking nuts?
Drew
Drew
