kick down cable to weber carb
    hi has someone fitted v mad weber carb and have the four speed fitted if so could you post photos of how you connected the kick down cable to the weber carb please as my car goes in soon to have this fitted thankyou stewart
    Hello Stewart.
    Thanks for the reminder!!! Got a new computer and having trouble downsizing photos. Please let me have your e mail address.
      Hello Stewart.
      John ,since the forum change over I haven't had to resize any photos ,the new software seems to do it for me.
      Cheers Steve
        I had trouble getting mine to change gear correctly as there wasn’t enough adjustment so I made a bracket to fit on the side of the carb carb.jpg
          I have now made up a couple of linkages for the ZF transmission cable. These will connect directly to the cable nipple, so the extra ZF cable link arm is not needed and needs to be removed. You may need to drill a new hole in the bracket to mount the cable in a new position as it seems the cable is longer than the Borg Warner one.
          I will send one to stagunhalf with the Weber kit, and perhaps John (koy23) would like to try the other (shall I post it to you John?). Please try them, and post a picture so I can see if they fit OK.
            Yes please Chris. Mine is held together with cable ties. Not good.
              I had a chap call in today to buy a Weber kit, and he had a GM auto gearbox on the back of his stag engine. I didnt expect to be able to help with the cable linkage, but when I had a look at it, it looked the same as the ZF! I never met anyone with a GM transmission before; it seems to be very similar to the ZF; 4-speed with overdrive and lockup.
              I gave him the same link as the one I made for the ZF, and he will let me know how he gets on.
                Hello Chris.
                Fitted the link you sent me, looks ideal, thanks, will test tomorrow.
