Nearly there but help needed …………..
    I have nearly finished the stag but there are a few things I could do with some advise on please, first how do you get no two piston to TDC on an auto ,
    And secondly I fitted new power searing hoses when I put the pump back but they are now catching on the lower knuckle of the steering shaft I have the pipes going over the top of the shaft and under the manifold is this right ?I cant see how else they could go
    John ,you will probily find your power steering hoses aren't quite the same as your old ones ,i had that but they are bendable with care.The best thing to do is match them up with your old ones before fitting but I guess that ship has sailed by now.
    Cheers Steve
      Cheers Steve
      Hi Steve
      Think I can get at them from underneath and do a bit of bending I didn’t what to start bending if I had fitted them wrong ,thanks for the help
        Hi John,
        I found that I had to carefully bend my new power steering hoses too in order to get a good clearance. They have been fine since.
          Hiya John, assuming your steering pump has a nut on the front, you can turn the engine over by pressing down on the top run of the belt, and using a spanner on the pump. Martin.
            I would never of thought of that thank you
              Originally posted by Gresley View Post
              Hi John,
              Ditto.
              And Martin's idea worked for me as well.
