Can anyone see anything wrong with my method of servicing the coolant etc, please:
What I did was:
1) Put heater switch over
2) take off one of the heater matrix bulkhead pipes.
3) Firmly attach water hose to that.
4) Ran water so it came out of the disconnected bit of pipe
5) took lid off expansion tank (mines a mk 2)
6) Put thumb over that tube so that water flowed up the coolant expansion bottle till clear and then left it running for a while
7) undid bottom hose on rad
8) take water hose from matrix thing and aim it down the rad through the bolt hole.
9) Take hose away
10) reconnect all pipes.
11) Put rainwater in rad directly through bolt hole with a third pink expensive) coolant. Did this till it got full
Then I ran out of time (2 am!!!)
So will finish tomorrow - priming and all that
One thing - I put the expansion tank lid on yet just pouring coolant into the rad hole caused coolant to come out of the overflow. I thought that was only used under pressure. It was acting just like a toilet cistern overflow if you know what I mean.
Wonder if the rad cap is knackered.
Anyone know of a halfords equivalent?
Ok - apart from that - did you believe my actions were thorough enough?
As always - thanks for any advice.
What I did was:
9) Take hose away
