towing
    towing
    where should the towing eyes be on the stag,sure I've seen a picy showing a towing eye beneath the front bumper? my car doesn't have any at all.
    peter.c
    There aren't any, Peter. Which is strange given the reputation they had. The picture you refer to was posted by Dasadrew, I think, of a (sensible) modification he has done.
      Dave's right, there aren't any. On the odd occasion when i have had call for one reason or the other to have a tow home, we have put a rope around the bumper mount and used that. Not that I've had to recourse to this action often you understand.
        towing eye
        Hello,
        This is what I built in using existing bolts.
        See pic.
        Good luck,
        Dieter.
          Originally posted by Dieter H. Marschall View Post
          Hello,
          See pic.
          Good luck,
          Dieter.
          dieter
          thats a good idea nice and neat
          what did you make it out off
            Hello Dave,
            Just a piece of round steel bent and welded to two U-shaped flat steels.
            Kind regards,
            Dieter.
              Any ideas for a similar attachment concept / point in the rear of the car? Thanks in advance.
                Tow bar?
                jason
                  Apologies, but I'm not exactly sure what you mean by tow bar. I thought tow bars were used for longer-distance towing where all four wheels of the car being towed are on the pavement and the car is simply attached to the tow vehicle with the tow bar. So then my question, assuming I am on the right path, would be where to attach the tow bar to the Stag assuming I am towing it from behind?
                  Thanks for helping me out - I'm just getting started with this and know I have a lot to learn.
                    Sorry, thought you meant towing with the stag! As there aren't any tow points as standard I have a tow bar fitted. The mounting points are the rear bumper irons with another section bolted to the boot floor
