Fast idle.....
    Fast idle.....
    right well, what with the upcoming events i think its time i got the idle sleep set.
    when cold its great but as the engine comes up to temp, the idle is too high, its around 1000 rpm,
    what with all the problems i had last year with the carbs I'm slightly cautious...
    i have checked that the accelerator linkage returns correctly... whats next????
    Ben
    Hi Ben, make certain both chokes are closing, particularly the nearside one as it operates the fast idle cam. You'll need a balancer to drop the idle speed properly, disconnect both carb rods first, make your adjustments then adjust the length of the rods so they don't alter the idle in either carb when you put them back. If it's an auto, make certain the kick down cable isn't too tight and holding the throttles open. Enjoy. Martin.
      Hi Ben,
      did you ever have one of the carb booklets i put together, one the guys gave me a link, if you PM me your address i will post one out to you
        It is an auto, the kickdown cable i did have a problem putting it back on after rebuilding the carbs.
        ill have a look at this.
          Originally posted by AlanD View Post
          Hi Ben,
          Yes alan i did
          i didn't think to look, I'm flicking though it now
          every time i use it ill donate
          Ben
            Thanks Ben, very generous of you
              Try disconnecting it and see if that changes things, if it doesn't, put it back EXACTLY as it was. Martin.
                My record idle speed is 4500 rpm .
                ... the end of the accelerator cable caught in the linkage, the approach to the first roundabout - following another car was a bit hairy!
                  Ill have a look on sunday and report back, i dont wanna get the old girl out, and started when i cant give her a proper run
                  I know a guy who does full tune ups for £50, hes about 150 so has been working with carbs and not ecus. so maybe it would be worth giving him a go
                  Ben
                    Ben
                    Your going to go all the way to Northampton to see Martin for a tune up??
                      Can't be me, I don't charge anything - though you're right about the age
                        if it was back in the day when fuel was cheap, they maybe i would
                        however... fuel is very expensive. so ill have to stay local
                        martin, unless you fancy a sunny south devon holiday?
                        Ben
                          That's very tempting, I don't think SWMBO would go for me getting dirty fingernails while she twiddles her thumbs. Martin.
