A couple of times I've had a severe crunch and horrible grinding of gears when selecting reverse - other times it works fine.
I was wondering (and this sounds daft) how do you select reverse gear? My handbook says , 'move the gear lever sharply to the extreme right and rearwards', but if I look at the ends of the selector rods where the bottom of the gear lever goes, the recess in the reverse selector rod is higher than the forward gears so I'm wondering if lifting the gear lever will ensure it goes all the way across to reverse as I'm thinking the grinding maybe because the lever is trying to move the 3 -4 selector rod at the same time as reverse.
Alternatively, has anyone had any success adjusting the pins either side of the gear lever pivot and can tell me how they adjust on a later car and wahat effect they have.
Thanks,
John.
Thanks,
John.
