Space saver spare wheel for stag
    OK, it seems like a daft question, but I need to get two complete paragliding kits plus camping kit in a stag and still leave room for SWMBO
    There is a lot of vacant space where the spare wheel goes, but I do not want to leave the spare out completely as if I cut a sidewall while offroading up a mountain, a can of tyre sealant ain't going to do the job.
    In my TR I have used a TR2 spare wheel and 125 section Citroen 2CV tyre to gain several inches of usefull space, and I could use the same on the stag (I have a rim but need tube and tyre)
    Does anyone know of a car with the same stud pattern as a stag, that uses a space saver spare wheel, as I should imagine they can be picked up from a scrappies for little money
    Thanks, Neil
    Have you got a towbar? If so you can make bracket or maybe buy one that can be mofified and fit the spare wheel on that................I did see somebody do that a few years ago.
      If you have a towbar, you could use a trailer.....
        Thanks, Neil
        my Saab has a space saver wheel i can let you know tomorrow what size tyre it has
          Neil,
          I think that the Stag's pcd and wheelnut spacing is the same as that of an MGB. If that is the case, a Saab 99 spacesaver will meet your requirement. I had one on an mGBGT that I used in an earlier life. Never had to use it, thouigh.
          FWIW
          Peter
            Put SWMBO in the boot-problem solved
              Neil, put a hard top on and then a roof rack, easy..................
              I prefer Bob's constructive advice
                Sorry guys, but the SAAB 99 pre-dated the space saver concept. Martin.
                  Perhaps it was the Saab 900 - definitely fitted MGBGT.
                  Peter
                    I did suggest it, but for some reason she wasn't keen
                      Have a look at this you should find one that will fit. http://www.carlsalter.com/wheel_fitments.html
                      Les
