This is how the Stag was when I bought it (less than £200) back in October 2009
It looks reasonable and the description on ebay was "a fairly sound rolling shell"
Well the rolling bit was a joke. As there was no diff in place the rear wheels were supported by the inner wheel arches (you can see the crazy angle they lean in at) where the VERY thick underseal became an exceptionally good brake! Still with the use of the winch mounted on the trailer we managed to drag the car on and get it home! Today saw the major welding work completed and now I only have some minor repairs to do to the boot floor. I did this after I had to cut the shell from the frame I welded it to so that I could transport it to its new home! Yes we had to move house 18 months ago after I had removed all the bits that would roll along with the bits that wouldn't
The car had been partially fitted with a rover v8 engine, see the tell tale hump in the bonnet. I have decided to keep this engine as the documents now received have the change noted. Apparently this engine swap was started by an earlier owner then all sorts of changes of hands took place but never recorded by DVLA however one of the more dutiful owners had obviously updated the V5 at some time because all the body numbers and the engine numbers match the current status. Anyway thats enough for now.
More to come over the next few weeks
