aldridge door trim panel"s
    has anyone purchased door trim panels from aldridges and if so how do they fit, and do they come with holes precut for door handles etc i would appreciate any information regarding this or any other door trim suppliers
    thanks
    Yes they come with holes, but they dont have the stainless steel strip at the top so you need to use your old one.
      thanks mate, was not sure how good a fit they were still i need them so will have to get them
        they are a great copy
        you will however need to buy some rivets from Bresco to secure some trim as you cant salvage them.
        its and easy job
        one other tip! buy yourself a heavy duty staple gun as you do need to use different size staples.
        When you have finished they fit a treat just be patient when you pull the glued foam off, use a blade to cut it rather than pull it off
        Good luck
          its and easy job
          Good luck
          You've lost me on this one! What are the staples, gun and knife actually used for? Aren't the Aldridge panels "plug and play" with the exception of the clips and chrome?
          Drew
            Should have explained
            Aldridge do sell the Door Card insert i.e the Board in the panel
            They are much cheaper than a full New Door card.
            Providing your existing vinyl is ok and your a bit practical you can do both in a half a day.
