I've read on here several times that the revs should drop when you remove the oil filler cap if the crankcase breathing system is all ok - still can't quite work out why though !
Anyway, on my car there is a very slight drop when I take the cap off but I think it's so slight that it points to a problem.
I've checked out or replaced the obvious (new breather pipes, new oil cap washer, new dip stick washer, new carb pedestal fibre washer) but I'll be b******d if I can think of what else to check.
Any thoughts anybody ? All advice will be very gratefully received.
