Hi All
Our Stag has DOT 4 in the brakes and clutch and the GT6 has DOT 4 in the clutch. This is because I have rebuilt all those systems. However, the GT6 still has Silicone in the brakes. Currently that car has its rear drums off as I am replacing the wheel bearings and UJ's. I would like to take the opportunity to replace the brake fluid with DOT 4 so both cars are standardised on one type of fluid.
Will it cause any problems with seals etc if I simply purge/refill/bleed the system with DOT4? Or can I only change over to DOT 4 if I replace the cylinders/calipers?
Bruce
Bruce
