Have just finished fitting new front brake pipes and on bleeding the system I find that there is brake fluid leaking out from where the pin in the PDWA switch locates. What I can't make out is whether its the valve, switch or connector that is at fault. The inside of the connector block where it locates into the switch looks as if it is made of a rubber type compound - is this meant to form a seal of some kind or does the fault lie elsewhere?
I've used DOT 5 fluid to refill the system and the car has been laid up for about 6 months now whilst the engine was being rebuilt there were no apparent problems in the past.
Any ideas????
Any ideas????
