Stainless rear bumper bolts
    I'm replacing my centre blade with a better item and despite loads of WD40 a couple of bolts won't budge, so likely to require a hacksaw job.
    So I was thinking while I'm at it to use stainless bolts, can anybody recommend a source of these as a full kit ?
    Hi Paul, I got these from LD Parts. They are the ones that hold the overriders on.
    Coach Bolt Socket Button M10 x 80 Screw CB6924SS
    £2.25 INC VAT
    Over rider Bolt or Coach Bolt substitute. The original type coach bolts cause mayhem in your bumper as they rust solid then turn and twist the square shank grab hole into a round hole, and then round and round they go.
    If the irons are straight the over rider+ rubber buffer+ Edge protectors + Socket button screw/nut assembly can be offered into the bumper and pulled up tight with the back nut.
    Peter, Cupar
