Stromberg mixture setting
    I have rebuilt the Strombergs on the Estate after experiencing flooding problems, and the mixture was still too rich at low revs when using the old needles and new jets, so I treated it to a new pair of needles, and the mixture is now too weak right through the rev range, with the needles wound up to the end of their travel.
    Float levels were set as per the book, and the needles were set to 1.7mm below the bridge as measured to the recess in the middle of the jet (1mm measured from the step at the side)
    I suppose the jets need knocking down a little more, I was thinking about 1mm, does that sound about right?
    Thanks, Neil
    PS the Estate passed its MOT yesterday, and I retaxed it today, Oh how I love tax exempt cars
    Thanks, Neil
    Hi Neil,
    I have a similar issue and toyed with lowering the jets, I fitted a set of recon carbs from a well know carb specialist (I bought them from someone who didn't end up using them) I couldn't get the CO above 1% at idle. I spoke to the supplier who assured me it would come up with use and is quite common!!!
    Having said that the car does run fine and shows no sign of running weak, Plugs, tail pipe or performance, running temp and so on. I will get round to checking the CO again but am quite happy with it at the moment so I'm not going to fix something that isn't broken as they say.
    Ironically it is a 73 so exempt from the emissions test.
      I don't know if this will help I will have to send it in 3 goes:
      Adjusting Your Carburetors
      1. Basic Adjustment Strategy
      The trick to tuning Skinners Union (SU) or Zenith Stromberg (ZS) carbs is to understand that there are two things you need to get right: the air flow, and the fuel mixture. While they are interconnected, they are also independent, and need to be measured and adjusted independently. SU carbs were used on the early Triumphs, while ZS carbs were used on the later ones. The design of each is quite similar; thus adjustment is performed in the same manner for either type.
      If you would like to read more detailed information about how your SU or ZS carbs work, there are excellent Haynes manuals for each of these carburetors.
      Special Tools
      • You will probably need to arrange to buy or borrow a Unisyn flow meter. The Unisyn is the usual gauge for getting the air flow balanced between the two carbs. This costs about $20 and is simple to use. It consists of an adjustable opening (same size circumference, but with a disc on a threaded rod that you can screw tighter or looser) that you use to set the level of a little float that rises or falls in a glass tube at the side of the gauge.
      • For the fuel mixture, one helpful device is called the Gunson ColorTune (maybe ColourTune, as it's a British co.). This is a spark plug with a crystal pressure- and heat-resistant window in it that lets you see into the combustion chamber while the motor is running. The color of the flame indicates the mixture richness. It costs about $40, and while it's not absolutely essential, it makes life so much easier that it's worth the cost.
      If you don't have a Gunson, the standard directions are included here for determining correct mixture (step 4 of the Adjusting Mixture procedure).
      • For some ZS carbs, you will need a special mixture adjusting tool. This is a special two-part wrench that is inserted through the top of the carburetor to adjust the metering needle while preventing the air valve from rotating within the carburetor.
      Terminology
      To tune SU or ZS carbs, first locate the following components:
      • Throttle linkage nuts. These are the things that connect the throttle linkage (the bar connected to your foot through whatever means your car uses, cables or rods) to the carburetors' throttle levers.
      • Throttle stop screws. These set the idle speed for each carb, and are located typically behind the dashpot, near the connection of the throttle linkage.
      • Mixture adjusting nut. On early SU carbs, this is the lower of the two nuts at the very bottom of the carburetor. Later SU carburetors of the HIF type have integral float chambers, on which the mixture is adjusted by turning a screw. Some ZS carbs do not have adjustable mixture. ZS carbs that do allow mixture adjustment either You'll need to experiment (and I explain how) to see which way makes this richer and which way makes it leaner.
      • Lifting pins. (SU carbs only) These are little wobbly metal pins under the dashpot. When you push up on the pin, it raises the piston in the dashpot. Find these; they're crucial if you don't have a Colortune. If you don't have them, can't find them, or have a ZS carb, you can raise the piston with a flat-bladed screwdriver pushed down the throat of the carb and twisted or levered to lift the piston.
      • The bridge. This is the part inside the carburetor, where the gas jet opens into the airstream. You'll see a needle inside the jet, and the jet itself should be a few fractions of an inch down from the bridge itself. The jet is the brass tube that sits in the center of the bridge, with a tapered needle poking down into it.
      • The choke linkage nuts. Comparable to the throttle linkage nuts (and usually the same size), but on the linkage that goes between the choke cable and the mixture adjustment mechanism. They make sure that both carbs are enriched when you pull on the choke. Your car may have no choke linkage, but a split choke cable which connects to each carb, in which you can forget about these...
      2. Before You Even Touch the Carbs!
      Start with the engine warmed up to operating temperature and perform your standard ignition tune-up (points gap, timing, spark plug gap, new condenser, etc.) first. All of these things can affect the setting of the carbs, which should be adjusted last, if at all! After being properly set, the carbs should rarely need further
        adjustment. If you've got a timing light and a dwell meter, you can verify the ignition components independent of the way the car is running. When it's warm, shut the motor off and remove the air filters.
        Of course, it helps if the carbs are in good mechanical condition as well. But you can consider a rebuild once you have gotten things working first!
        3. Balancing The Air Flow
        If your car has multiple carburetors, the air flow needs to be balanced amongst all carbs before the mixture is adjusted. If you have only one carb on your car, you can proceed directly to mixture adjustment!
        1. Begin by balancing the air flow. To do this, first loosen the throttle linkage nuts. Leave them connected, just loosen them half a turn or so.
        2. Back out the throttle stop screws till you can see that they are just touching the throttle stop. Then open each carburetor (that is, lower the throttle stop screw) 1-1/2 turns of the throttle stop screw and start the engine. It will probably idle at about 2000 RPM; don't worry.
        3. Put the Unisyn over either carb and adjust the orifice in the Unisyn till the little float at the side rests at the middle of its graduated tube. (Pre-diagnostics: if the idle drops and the car wants to die when you slap on the Unisyn, the carb is too rich; if the idle soars upwards, it's too lean.) Hold the Unisyn over the carb for only long enough to see the level of the float, then remove it.
        4. Place the Unisyn on each carburetor in turn to check its flow, adjusting the throttle stop screws until all carburetors register the same position on the graduated tube of the Unisyn. (The float will probably move either up or down in the tube, which is why you want to center it in Step 3.) When both carburetors flow the same amount of air, tighten the throttle linkage nuts, adjusting for the amount of free-play between the linkage and the throttle stops that your manual calls for (probably about 0.006"). Your goal should be to achieve the lowest possible idle with both carbs balanced and the engine running smoothly. (Note that the idle speed will very probably rise as you get the mixture correct.)
        5. If you've taken more than five minutes to do this, rev the engine to over 2500 RPM (assuming the idle isn't already that high) for thirty seconds or so to clear the spark plugs. Then adjust the mixture.
        4. Adjusting The Mixture:
        Note: in the following procedure, one "flat" is the basic increment of adjustment, and refers to 1/6 of a turn of the mixture adjusting nut. This corresponds to the flat faces on the nut.
        These instructions are for ZS carbs or SUs with separate float chambers. You will need to check in your shop manual to see whether you turn the mixture screw to the right or the left to make it richer or leaner. (We may add the information here some day...)
        1. Shut the car off and loosen the choke linkage nuts, if you have any to loosen!
        2. Adjust the mixture nuts (screws) fully lean. Check your shop manual to make sure you are adjusting them the right way!
        3. Now enrichen each carb an equal amount -- two full turns of the adjustment nuts (screws). Then start the car.
        Note: In the following step, you might want to consider adjusting the carburetors one-half a flat too lean, as the mixture will be enriched when you put the air filters (which restrict air flow) on at the end of the tuning process.
        1. Raise the lifting pin (or use a screwdriver if you don't have the pins) so that the piston rises no more than 1/16". Listen to the engine's exhaust note and compare it to the following conditions:
        o If the exhaust note rises and stays high until you drop the piston, this carburetor is adjusted too rich. Adjust the mixture one flat leaner, then repeat Step 4.
          • If the exhaust note falls and the car sounds as though it is going to stall, this carburetor is adjusted too lean. Adjust the mixture one flat richer, then repeat Step 4.
          • If the exhaust note rises briefly and then settles back down to something like the original RPM level, this carburetor is set correctly. When you have achieved this setting for all carburetors, continue with Step 5.
        1. Tighten the choke linkage nuts, if applicable, so that the choke cable will pull an equal amount on both mixture nuts when you pull the knob.
        2. At this time, I find I usually have to adjust the idle again because getting the fuel mixture right usually changes the idle speed. Since you know you have the throttles synchronized, I normally just adjust the idle without loosening the throttle linkage. The easiest way is to screw one of the screws out till it doesnt' even touch the throttle stop, then use the other to get the idle speed right. When that's done, you can screw the other stop screw down till it just touches the stop on that carb and you're set.
        3. Replace the air filters and go for a test drive!
          Last bit:
          5. Special Notes
          SU and ZS carburetors are most fuel-efficient when slightly lean, and provide the most power when they are slightly rich. You can use this knowledge to provide a certain amount of tuning for the kind of driving you do. If you learn to read spark plugs, you can get a basic idea of what your engine's condition is and make fine adjustments to the mixture nuts accordingly.
          If you have a ColorTune, you simply install it in place of one of the plugs, then adjust the carburetor that feeds that cylinder (the front carburetor for 1 & 2, the rear for 3 & 4). The ColorTune will let you see the color of the flame. White flashes mean too lean; yellow flame means too rich. Blue (like a Bunsen burner) is correct, and blue with a faint orangish tinge is the best for power.
          You can also modify your car's throttle response characteristics slightly by adjusting the viscosity of the oil in the dashpot damper. SU and ZS carbs are set up so that a thicker oil will resist the piston's attempt to rise in the dashpot for just long enough that the engine's increased load (when the throttle is opened) will pull more fuel across the bridge; this enriches the mixture and temporarily bumps power up to help the engine achieve higher speed more readily. For light damping, Marvel Mystery Oil is excellent, engine oil can be used for heavier damping.
          If you modify your engine, you will probably need to modify your needles, as it is the needle profile that determines the mixture curve for different air-fuel loads.
          If you experience uneven idle, hunting, or an idle that changes (rises or falls) as the engine's temperature climbs or drops, you probably have vacuum leaks. The most serious fault on most old carbs is wear in the throttle shaft area. To test for this, spray some carburetor cleaner on the outside of the throttle shaft; carburetor cleaner is non-combustible, and if the engine speed drops, it means some of this is getting into the air stream from outside the carburetor. You may also have leaks from the manifolds, from tubing such as the vacuum advance line to the distributor (if fitted), or from other places; the carb cleaner trick works well for locating those leaks as well.
          Other problems that SU and ZS carbs experience involve dirt in the dashpot and occasionally in the float chamber. The dashpot is a precision piece of machining that involves very close tolerances so that the piston doesn't stick or bind when it rises and falls. A little grit between the piston and the dashpot can make the car jerk and sputter. Take the dashpot off, wipe the insides down with carb cleaner and a lint-free, clean rag, then reinstall it, getting the screws down tight. Also, don't swap the pistons between dashpots; they're matched to one another so that the clearance between the piston and the wall of the dashpot makes a tight seal but permits easy rising and falling.
          Dirt in the float bowl basically shuts off that carburetor (or can make it flood open, depending on whether the dirt is wedging the valve open or closed). You can try rapping on the float bowl with the handle of a screwdriver, but your best bet is to take the cover off, clean out the valve fittings, and reinstall everything, with a new fuel filter for good measure.
          Some older SU models also have adjustable floats, in which you need to set the float height (which basically equals the fuel level in the float chamber) by bending a brass rod. These carburetors were replaced in the mid-1960s with carburetors that had fixed, plastic floats which are basically trouble-free unless abused. The stop at the back of the floats can break if they are installed badly, and the brass pin that holds them in place can wear an oval hole in the float pivot. New floats are fairly inexpensive and aren't a bad idea if you're doing a rebuild.
          Grose-Jets are very popular with some people and a big pain for others. It appears -- and this is just conjecture -- that Grose-Jets work best in cars with adjustable floats. The standard failure for Grose-Jets is to flood the carburetor.
            Neil.
            Just refurb my carbs and replaced the jets but could not find a definitive answer as to the depth of the jets, so I measured the old jet depth and set the new to be the same 0.098" using the verniers. This seems OK but it still seems to be on the weak side just borrowed a Co meter for the weekend to see what it its finally like. To set the Airflow I used an Anemometer ebay No 350309713695 this works just great no fiddling with floats in tubes, I found the metres per second flow rate was ideal and at 800rpm each carb flows about the 4.0 m/sec.
            Back to the jet depth I still do not have a definitive setting I think it needs to go down a bit more, trouble is don't like taking a hammer to a carb seems a bit odd to me .
            If you find out what the depth should be I would be interested has any one got a copy of the old Haynes Stromberg manual and is the information in that before I go off and buy one?
            Paul.
              Hi Neil,
              there was a thread about this a while ago, about the depth of the jet and that they were set too low, bu----ed if i can remember who it was though, have you tried the Buckeye site?
                Was it this one?
                http://www.stag.org.uk/forum/showthr...ueter%2Bbridge
                Klaus
                  yes that's the one mate
                    Hi Neil,
                    I am 99% certain the measurement of the jet height is taken from the outer part (i.e the step), not the inner recessed part.
                    When I did mine recently, it was far too lean, and the reason being the jet was not down far enough because I measured from the middle.
                    Cheers..Al.
                      Thanks for the advice everyone. If the depth is 100 thou I think I will grind down an old tappet shim of that thickness to a loose fit in the jet holder, then I should be able to tap them both down to the same depth. If I use a nice wide punch, I won't knock it in too deep, or batter the end of the jet with the punch
                        Cheers..Al
                        Sorry Al, but are you sure you had the correct needles installed? There are so many wrong needles on the market (to slim or to thick) which gives a fat or lean mixture even with the 100 thou to the inner recess.
                        Klaus
                          I cut down an old 100thou tappet shim today, and it made the perfect tool for setting the depth of the jets, well worth the effort. I measured how much further the jets had to go down and it was 65thou (I measured from the recess in the middle of the jet the first time, rather than the edge)
                          Coincidentally, the jets were wound 65 thou up into the pistons, where they ran out of travel. At least with the jets wound level with the bottom of the pistons I am starting from the same values as I had before I adjusted the jets, so I should have plenty of adjustment left.
                          I didn't measure the old jets before I took them out as I could see they were not at the same level, that is part of the reason I changed them
                            Neil,Cant believe you haven't binned them,Are you sure you don't want that plenum base.i'll have the top going spare as well i think ,going to have to make my own.
                            Cheers Steve
                              Ok - excuse me for hi-jacking the thread but I have a really basic question that I can't seem to find any examples etc (or my searching is rubbish).
                              I bought a Colortune kit and a special tool to do the mixture bit.
                              From what I see, you're meant to take the black plastic top bits off the carb (the once that make a squelch feeling when you pull it up and push it down - you can see how technically astute I am). Anyhow - it looks like you push the tool down the now open top of the carb and turn something within.
                              There's a fairly clear carb-to-cylinder relationship and I've got half tan spark plugs and half black spark plugs - so nice and 'obvious' - even for me!
                              When putting this tool down the carb does one turn clockwise for richer or is it the other way. The rest I can probably work out.
                              Obviously I would like to fix this for mpg + bhp and less smell!
                              AFAIK they only do visual checks on a ('73) stag for MOTs - is that the case anyone. Actually - that's a bit off topic - I'll start a new thread.
                              Cheers for all your help
