Hi all,
In a recent thread Chris (Vmad) wrote:"Vapour lock seems to be getting more common with modern volatile fuel; wether Ethanol contributes to this I am not really sure. What do you think Klaus?"
Well, here are my thoughts and experiences:
Yes Chris, I have the strong feeling that your assumption is correct and fuel characteristics have dramatically changed since some years --at least in Germany.
Since approx. three years I have problems with unreliability of my Stag concerning fuel management. The fifteen years before faults were always based on mechanical/electrical problems. But now it is different - let me try to explain:
When I run the Stag in early spring or autumn with moderate outside temperatures no problem at all. But when it gets warmer like now with 20 to 25 C the following happens
- start of the cold engine: perfect
- driving let's say downtown Munich and parking for ten to fifteen minutes with the warm/hot engine the next start is again perfect. But then it is not possible to spontaneously accelerate. She runs with constant speed (slow) for around 100 metres and then, all of a sudden acceleration works again without problems.
(BTW: I have perfectly refurbished my Strombergs with really everything thinkable).
So I decided to no longer play around with float and vent valves and complain but try to find the reason. And I am meanwhile convinced that it can well be the fuel.
At first I measured the temperature of the fuel hoses in the warm/hot engine area (ambient temperature approx. 23 C):
- At the filter ca. 50 C
- above the LH rocker cover ca. 65 C and after 10 min. (engine switched off) 70 C
- fuel inlet port of the LH carburettor ca. 70 C
Secondly I intalled a pressure gauge in the fuel line in front of the filter (see pics. ) which is now located below the dashboard. Very interesting:
- my Hardi fuel pump ( No. 14412, very reliable) feeds between 0,22 and 0,3 bar.
- stopping the warm/hot engine the pressure stays at around 0,25 and 0,3 bar
- and now: watching the gauge during the next minutes I can see the needle slowly moving up and the maximum pressure I measured was 0,52 bar
That means the standard float needle valves are really closed to hold 0,5 bar.
Question: Is the pressure increase based on vaporisation of the fuel in the hot hoses or carbs?
Then I studied the literature - interesting: In former times the fuel was called in Germany "Vergaserkraftstoff" - translated "carburettor fuel" - with vaporisation starting at around 100 C. As all vehicles nowadays have fuel injection working with higher pressure the vaporisation temperature was not important and dramatically reduced. The first fractions start now to vaporize at approx. 60 to 70 C. Is that due to cheaper fuel production?
Verdict: At the moment I am convinced that - given the engine management (fuel/electric) is in first class condition - most of our Stag problems with starting or running hot is related to the above mentioned facts. If all this is correct what can we do? My thoughts:
- get rid of the increasing pressure when the engine is stopped. I am working on that and will report my experiences during the summer
- get temperatures above the engine down (louvres, insulated fuel hoses,running the electric fan for a while when the engine has been switched off or what else?)
- try whether a "Gasblasen Abscheider" works sufficiently (I do not know the correct word, somethíng like "gas bubble separator" - Drew please tell us the correct terminus)
- find out more technical specs about vaporisation of E0, E5, E10, Superplus etc.
- Do other carbs have the same problems? (Weber, SU, Holley etc.) and if not why not?
- is fuel injection or TBI the only solution?
- Are there differences from country to country?
- I am very interested to hear your thoughts and comments and of course ideas to overcome these problems. Perhaps I am on a totally wrong track - please let me know.
Klaus
Klaus
