Hi, I am starting to hear some creaking noises and other sounds (what sounds like sticking splines) coming from my drivers side rear driveshaft. I would like to fit a new set of driveshafts but they will need to handle the punishing power of my Chevy LS1. I am fairly sure the Datsun driveshaft conversion will not handle the power. Does anyone know the power handling capability of the Rilsan GKN solutions? Are there any other solutions?? Thanks Spin.
Are there any stronger Stag driveshafts that can handle around 350HP?
GuestTags: None
BMW E30 Rear end complete with diff/shafts/disc brakes.
You aren't putting 350BHP through the standard stag diff are you?!
The rilsan coated driveshafts are still the standard shafts but coated in 'rilsan', as far as I am aware?
Nice problem to have!!
MikeMike.
Guest
Originally posted by mjheathcote View PostBMW E30 Rear end complete with diff/shafts/disc brakes.
MikeNo I have a BMW E30 LSD but have it all going through the Stag driveshafts. I knew the driveshafts were the weak link and it is to be expected with the power but now I need to find something that will cope.
. Spin
Spin, I'm sure a man of your talents could make the bmw driveshafts fit onto the old stag hubs.BTW, really pleased with my BMW transplant now i have finally got positioning,tyre size,diff ratio etc sorted out.
Cheers SteveLast edited by Stagdad; 21 May 2011, 13:49.
Guest
Originally posted by Stagdad View PostMike, did you get the one you asked me about in the end?
Cheers Steve
Guest
Originally posted by cosworthstag View PostMy Stag has datsun drive shafts and BMW LSD it run ok at 400bhp next week taking power up to 500bhp will see what happens to the drive shafts
Looking forward to photos of those 'licorice twist' driveshafts next week, Spin
Its a BMW subframe, the limited slip diff has a ratio of 3.08.1
currently have limited the turbos to 5psi to run in the engine a bit going to increase to 12/14 psi on the rolling road.
The engine is capable of 600bhp+! but entend to stop at about 500bhp
The Stags currently at http://www.topbossperformance.co.uk/ who have built the engine and fitted the larger all round disc brakes
The clocks are all digital
full spec is
Engine tunable to 600+ bhp
Brakes 330mm front
280mm rear 4 pot calipers on front and modifiedbrake discs on front
BMW axle
T5 gearbox transmission and fastroad clutch
Lightened and balanced flywheel
Custom made tubular turbo manifolds
Custom made intercooler
Twin turbo
uprated fuel pump
Currently untuned running 400 bhp
Cosworth V6
Carbon fibre dash
Iridium digital clocks
S/S custom made exhaust
Polyurethane bushes
Spax suspension
Clifford security and remote startalarm
Alchemist 17" wheels
Guest
Excellent, seems like a new era has arrived for the Stag!
One of those V6 Cosworths would go well in my 1981 Lotus Esprit.
Are you aware Peter Hills on this forum is looking for wildly modified Stags for articles in the Mag?
Let me know how those Datsun driveshafts go. Spin
