I have an MOT on Friday and my brakes are duff! With full effort on the pedal I cannot get the front wheels to lock up.
The system (all standard setup): Master cylinder (unknown)
New bits: brake lines, flexible hoses, caliper pistons & seals, discs, wheel cylinders & linings.
The pedal is going down too low for me. I have tried to test the master cylinder by holding a lot of pressure on it for a couple of minutes & the pedal does not sink. The servo is working OK. I have pressure bled the system three times now & there is no fluid loss. Everything is moving as it should OK. Nothing sticky.
Could it be the master cylinder? I would have thought if it holds pressure for such a long time it was OK.
Cheap, nasty pads maybe?
Please help!
Gavin
Please help!
Gavin
