Hi all,
Help. Can somebody help before I go mad. I had a water leak from the manifold gasket a while ago and replaced the gaskets. I obviously didnt tighten it down enough as on filling with water the leak was even worse. I therefore replaced the gaskets again and used new bolts to refit the manifold. On replacing the carbs I find that the throttle linkage now holds the throttles almost wide open. Removing the linkages and it idles Ok but even making the linkages as short as possible, I have shortened them by about 1 inch, they are still too long. What have I done?, How can they be too long, they were OK before. I took carbs off as 1 complete unit. Can you get shorter links?
Thanks Guys
Thanks Guys
