Soft top alinement
    Soft top alinement
    Could anybody tell me ( before i start pulling it to bits ) if there is any adjustment in the soft top so it clears the boot hinge. thanks
    Hiya, the rear hoop section, holding the rear window, has three bolts along the bottom edge on each side, these pass through large holes and give a fair range of adjustment, do be careful, mark the position of each bolt before you start. Chris (VMad) can give you details of the best way to set it up. Martin.
      Thanks Martin i will let you know the outcome...Steve
        Martin I sorted the problem with my hood, it was one of the spring loaded latches not doing its job on the way down to the stowage compartment.
        I have persuaded it otherwise and the problem is solved thanks...Steve
