overfilled auto box
    overfilled auto box
    If some idiot inadvertently overfills an autobox to the point where oil is now seen underneath the box after a run, what does that mean? is it doing damage to seals etc. or can I leave it?
    Said Person should drain the Gearbox to the correct level as there is the risk of seal damage!!!!!!!!!!!!
      dont these gearboxes have an overflow fitted to them that goes behind the servo????
      KKK ***N WHITE TV8 AUTOMATIC,STAINLESS STEEL EXH,ALLOYS,
        Del, that's the breather tube Mate. normally it will come back up the filler tube first as it's lower. it's a common fault, mine has done it before. it's failure of the converter drain back valve I believe.
          I thought if you overfill it,just finds it's own level by throwing the excess on the floor.
            okay ian i thought when these engine stopped it returned the oil from the convertor back to the box???
              Hmm - i suspected as much. I've never been very good at draining a little out of an engine/ gearbox and it always ends up on top of me - but will have a go. Thanks
