low oil pressure
    low oil pressure
    Putting the old bird (Stag not wife) on road after the annual 6 month Sorn and the oil pressure is reading 15-20 on tickover and 40 at 3000 rpm. I've had the compression checked and it is fine. Also no stange rattling from bottom end. I suspect it may be the gauge or the sender (where is this located?). Any other suggestions?
    Also, if it is the bottom end can this be done with the engine in the car?
    Before Sorn, pressures were much higher.
    Sorry about all the questions
    Robbie
    The sender is at the rear of the engine on the drivers side near the auto dipstick (not much help if you're manual)
    Maybe an oil change would be prudent? then see what the pressure's like:?
      Hi Kevin thanks for response.
      Are senders prone to problems?
      Robbie
        Hi If those are the pressures of thehot engine I wouldn't worry at all. It does seem a little odd that they were higher before though:?How much higher
          Hi.
          before, tickover was 20-25 and about 50 at 3000 rpm. The oil and filter have been changed.
          Am I being concerned unduly?
          Robbie
            Robbie
            Not that I know of
              Hi,
              You don't say if the oil pressure gauge isan electronic one or a capiliary oil fed version? Electronic ones can fail - I had one go on a Lotus, which manifested itself as low readings, and then eventually a 'flicking' needle.:shock:
              Capiliary fed versions can leak - but you should see the result of that.:P
              You may have a sticky pressure releif valve in the pump.:?
              Either way, I would change the oil and filter and then take it for a long drive and get the oil nice and hot.
              Chris
                I'm with V8 rumbler .Those hot pressures are the same as mine and my engine seems fine,no noises or smoke.
                  My engine runs at 25 psi at tickover (hot) and at 3000rpm 50psi. This is the normal pressures you should see from an engine in good order.
                  Stuart
                    Your type/brand of oil can affect the pressure
                      What oil have you used? What filter? Do you have the original paper filter cartridge, or a conversion to a modern spin-on filter?
                      All these will help us diagnose the problem if you have just changed the oil/filter and the pressures are lower.
                        Bob, thankyou. You got it spot on. Changed the oil to Unipart 20/50 and pressure back to normal.
                        Lesson - don't buy cr*p oil (ZX Premium) from your local autoshop!!!
                        Thanks to all for your advice
                        Robbie
                          Robbie
                          I Do like a happy ending
