Worth checking all areas for coolant leaks!I though the engine was losing more than normal and expected the worse.
This is how the heater looked when I got it out. The valve turns by hand but I usually left it open. I reckon it was forcing the hoses on and off that eventually weakened the connection, there's nothing holding the pipes to the car body so they will move.
I've soldered it back together, hopefully pipes are at correct angle and I'm going to put a self tapper in where the pipes come through bulkhead to hold in place.
Its a a pig of a job getting the heater out tho!
