Cavity Wax - which do you recommend - Dinitrol or Dynax?
    Hi All
    Which of the following two products would you recommend as a cavity wax on a Triumph?
    • Bilt Hamber Dynax S50
    • Dinitrol 3125
    Bruce
    Hi Bruce, I use dynax S50 myself. I like the Blit hamber stuff, I also use their underseal, UB something??? and their shampoo, clay bar and polish!
      Hi Jason.Bet you smell lovely
        bet his got flowers in his hair as well
          Hi Bruce,
          I have had excellent results with Dinitrol 3125. I also find the Rustbuster stuff good too.
            I have used waxoyl over the years, never been very impressed by it, but having just tried the bilt mamber dynax, i will never use anything else for "blind" cavity work. It quite obviously creeps into seams in a way waxoyl simply does not. I like dinitrol's metal loaded filler, it's really easy to use,I have no experience of their cavity wax, it may be good too, but frankly i'd be surprised if its any better tan dynax.
              I've used the dinitrol Kit including the cavity wax for 5 years since i bought the car and cant see any difference in the condition of the bodywork in that time so guess it must be doing its job.
              Howerver the 3125 is thick and more for a base coat for the black 4941panel sealer,the stuff you get in the kit for box sections and cavities is in a spray can and is ML which is thinner and runs every where including out of the drain holes so put some paper down .
                Dinitrol ML for the cavity sections........ Andy
                  Hi John, I do!!! Nothing better than a rub down with a clay bar!!
                    Beats Lynx any day
