Door Lock Adjustment
    Hi all
    My 75 Stag if fitted with Mk1 door locks.
    Are the locks adjustable?
    I find that to unlock the door requires only the slightest movement of the key where as locking it requires rotation of the key through a full 90deg or more and vice versa on the other door. Surley this isn't correct.
    If there is adjustment could someone please explain to me what i need to do.
    cheers
    Sean
    Hiya Sean, I wouldn't worry too much about locking the old girl, you can get into most Stags with a tea spoon - or a Stanley knife. Martin.
      I seem to remember thats normal for Mk1 locks. So long as they lock does it matter?
        Martin
        I appreciate that, hence imobiliser and removable steering wheel fitted.
        Would still like to get the locks right though.
        Sean
          Chris
          I guess not. The movement is only a hairsbreadth to unlock which can't be right and its one of those little things that bugs me
          Sean
            [QUOTE=wolfie;150548]Martin
            Understandable. I like the idea of the removable wheel. Martin.
              [QUOTE=martin;150561]
              Originally posted by wolfie View Post
              Martin
              I take all 4 off mine when I park it!
                Hi Sean
                Having just been messing with my locks,what I would say is providing you do not need to use unnecessary force to lock/unlock the car your doing well because if you did you run the risk of snapping the flimsy original key.
                When you lock the door a bar comes across which stops the process of the mechanism releasing the door,over time everything in this area tends to get a lot of slack in it,I do believe only s/hand locks are available and they could be a whole lot worse than the one you have on your car.
                Mark
