Oil Pressure Switch - Wiring
    Hi,
    The oil pressure switch is not connected as the wire appears to have snapped off somewhere along the way, I have looked near at main loom near the witch but can't see any evidence of it. Although I have a gauge fitted I'd like to get this connected back up. Am I right in thinking that all I need to do is run a wire from the switch back to the warning light cluster? I note there is a link with the brake warning light witch and light.
    Thanks,
    Paul
    Hi Paul
    There should be a white/brown wire connecting to the oil pressure switch which goes back to the warning light. The other side of the oil warning light connects to the brake warning circuit. Hope that helps.
    Simon
      Yep Thanks. New wire connected in and oil and brake light work for first time since I've had it.
      Cheers.
