help with a '73
    help with a '73
    greetings from the USA! hoping someone could shed some light on some questions i have, first a little back story:
    my father has two stags, a '73 and a '71....the '71 has a V8 with (what i believe is) a 3 speed auto gearbox...it is in rough shape, and i believe the engine is frozen...the '73 no longer has the triumph V8, but has been swapped at some point to (what i think) is a triumph straight 6 (probably swapped due to the overheating issues i've been reading about)...i know this engine runs rather well, but the car has been sitting idle for a few years now....
    my father rarely has time free, and the stags have taken the back-burner for as long as i can remember...i've recently decided to work on the '73 (better of the two) as i have the money and time, in hopes that i can get it to a point where he can work on less time-consuming issues with it...
    questions:
    1. from my research i've decided that the straight 6 is either the 2.0L from the GT6 or a 2.5 from a TR6...how can i tell which engine it is? i know it needs a new alternator, valve cover gasket, and the fuel pump is going...are these parts interchangeable between the 2.0 and 2.5? i has twin stromberg carbs if that helps at all
    2. at least one of the rear brakes is frozen and both front calipers are frozen...where can i get some decent replacement calipers, wheel cylinders, rotors, drums, etc. ?
    3. what size tires should it have? it has the 14" 5-spoke alloys....i've read that it should run 195/70/r14 , but right how it has some dry-rotted 185s...does it matter?
    4. the '71 has the 72 spoke wire wheels with spinners...is it easy to swap the hubs over ? i'd like to have the wire wheels re-finished at some point in the future
    5. anything i should be aware of while while doing general maintenance to get it back in shape?
    i wont be performing a full restoration on it, i can't imagine my dad will either...just looking to get it back in gear so it can be enjoyed
    try these also look in clearance http://www.rimmerbros.co.uk/ItemList...ue?src=TRIUMPH
    www.ldparts.co.uk
    www.jamespaddock.co.uk
    www.ejward.co.uk
    www.robsport.co.uk
      Hi name?Welcome to the forumItem 2 LD parts are a good bet for the brake bits.I used to have a 2L vitesse with a pair of stroms and I think they are CD150's on the 2L and CD175's on the 2.5L so check the size of your carbs,thatmay give you an idea which engine you haveCheers Steve
        This should help you identify the engine :
        http://www.triumphspitfire.com/enginenumbers.html
        C
        heers
          Where are you in the US I am in california can you PM me.
          cheers Stuart
            thank you all for your help
            that engine number chart is very helpful....although, when i looked at that spot on the engine, there were no numbers whatsoever maybe the engine was stolen and serial numbers scratched off ?
            after more research, i'm almost positive that the engine is the 2L from the GT6....i ordered a new valve cover gasket, new fuel pump and filter, lucas alternator & v-belt....i also picked up new rear brake parts, including shoes, springs, and wheel cylinders
            stuart, i am in New Jersey
              The 195/70 14 tyres (sorry tires) will cause some speedo error but thet're a pretty common substitute for the original 185/80 14s. Swapping the wire wheels is pretty easy on a Stag they just bolt onto slightly shorter studs on the same hubs. you can buy new studs easily enough or try to swap them over.
              Good luck
              Nick
              Nick
                That going to be about 100bhp then 30% down on the V8,the 2.5 is a lot closer.I sure its still fun though.So has it got cd150 stroms?
                Cheers Steve
                  thanks for all the response, i'm going to look into swapping the hubs over and restoring the wheels in the future, for now i'll just put new tires (tyres ) on the 5 spokes
                  yes, it has zenith stromberg cd-150 carbs
