I've a recurring leak from the auto box of my, otherwise pristine, 74 Stag. I think that's its the 35 Borg Warner box, reconditioned about 18 months ago. I'd done 3k miles or so since the recon with no leak or other problems.
Suddenly, after the car had been standing idle for a day or two, a large quantity...maybe 100-200mls.... appeared on the floor. The car could still be run with no further leakage, but the box sounded a bit whiney and clunky with occasional apparent torque converter slippage. Obviously, I've refilled it but the problem has twice recurred, with another oil puddle under the car. Ashamed to say I've done nearly a further 1k miles with it in this condition!
I've read vague posts about a sticking valve inside the box which allows oil to drain down from the torque converter into the gearbox, causing it to overflow through a breather pipe...and this explanation seems very consistent with my particular symptoms.
Is anyone familiar with this problem? Is there a simple fix? Is it ok to drive it with low transmission oil, topping it up periodically. Sounds Heath Robinson, I know, but I have the car in ITALY for the whole summer (with no cooling issues so far!) without a workshop or access to expert assistance... I am trying to muddle through until I return UK for a permanent fix. Meanwhile, HELP!
