Hi Folks
This is really beginning to niggle me because I think I've fixed it and then it comes back again.
If I go for a good run which includes a dual carriageway or motorway section ie 60mph plus, as I lift my foot off the gas for a roundabout etc the revs drop to zero and the engine cuts.
An on the move "bump start" gets her going again immmediately and then its a case of gently down the gears or blipping the throttle to keep the revs up. Town driving is fine.
My first thought was dashpots but these are nicely topped up. (should I check the piston movement in there?) I replaced fuel and air filters, and plugs and given the carbs a good dose of cleaner. No apparent air leaks in breather system. It just like it doesn't like rapid power decrease.
As always, any pearls of wisdom from the carb experts greatly appreciated ...I'm assuming it's carbs...original Strombergs by the way
 Martin.
  Martin.
