Having done a good bit to electrics lately which needed leaving the ignition switched on I noticed my pump keeps ticking.
I would expect an SU pump to stop when the carbs were full....
Looking under the bonnet I noticed the drivers side carb was leaking fuel via the spindle....then I looked at the dipstick and it seemed a bit
fuller than it should and I thought it smelled of petrol but that could be psycholigical.
Anynoe else had a stag dilute its oil with fuel? If the float valve sticks as they sometimes do I'd expect the fuel to come out of the overflow, not drop into the inlet manifold and hence the sum via an open valve.
I'll do an oil change as a precaution.....cheaper than a rebuild!
Jonners
Jonners
