I attach a link to an excellent and informative article http://www.pumaracing.co.uk/POWER3.htm
The bottom line is forget the 'Flywheel' BHP you should only compare the figure at the wheels. Interesting to see the effect of tyre pressures. Also the article puts to a fairly convincing argument to suggest it is pointless using a rolling road dyno to compare with manufacturers original figure. Also if a high 'At the wheels BHP' is your aim forget that automatic or overdrive both soak up power. Use a manual without overdrive and pump up those tyres!
Also I spent a long time talking to the tuning expert from the 'Extra EFI' stand. His knowledge of tuning race engines was immense. What he said to me was people often come to him with a Cobra or TVR and say 'I want 300BHP at the wheels'. He say 'Yes I can do that but will you only be using it on Track days?'
His point is that peak BHP is achieved as a compromise to other factors. If you are on a race track and have enough gears to constantly keep the engine in the, now narrow and high RPM, power band then you will benifit from the extra peak power. If you want to use the car as a road car then you may well end up with a slower 0 - 60 time and a car that is a pig to drive.
For our type of cars and for our type of driving 'driverability' and 0 -60 are more important than striving for 'Peak Power'
- Alan
- Alan
