Hi everyone!
My name is Jon and I run a musical instrument restoration and repair business with my other half in Derbyshire.
We only drive classic cars. Modern cars just don't really do it for us! We currently have 2 classics - a '75 MGB GT Factory V8 and the latest addition to the fleet behing a chocolate brown '77 Triumph Stag. The car is manual overdrive and still has the original (recently rebuilt) Triumph V8.
The car has developed a bit of a strange problem with respect to the overdrive.
After a days driving, coming down a hill in third gear with overdrive engaged, it suddenly decided to switch out and re-engage.
This happened a few more times over the course of the remaining mile back to the house. By the time we got home the o/d wouldn't engage at all.
I've checked the wiring in that I've checked with a test bulb that there is current going to the gearbox with the engine running, gear lever in the 3rd / 4th position on the gate and eliminated the switch.
I've also drained the oil in the gearbox, cleaned out the mesh filter with carb cleaner and reassembled and refilled the box with EP90.
Since doing that, very occasionally I am able to engage the overdrive. However, when I flick the switch, the overdrive will engage for around 1 seccond and switch straight back out again on it's own. If you try and get it to engage again by flicking the switch it won't attempt to engage. However, if it is left for at least 10 minutes it will repeat it's 'in for 1 seccond and straight back out' antics.
I'm a bit stuck as to what to look at next. Clearly the o/d works in that it actually engages momentarily so there *should* be some sort of fix underneath the car without having to resort to taking the gearbox out?
-JC.
-JC.
