well i am completely confused. I am pretty sure the whole point of a header tank is that there is some flow through it. The small diameter of one of the pipes means that the amount of flow is miniscule compared to the thousands of gallons per hour the pump is capable of. If you have both pipes on the same side of the rad then as far as I can see all you get is the same effect as just raising the level of the existing expansion tank. Maybe I am missing something?
Another Header Tank Question
Originally posted by Ian Durrant View Postwell i am completely confused. I am pretty sure the whole point of a header tank is that there is some flow through it. The small diameter of one of the pipes means that the amount of flow is miniscule compared to the thousands of gallons per hour the pump is capable of. If you have both pipes on the same side of the rad then as far as I can see all you get is the same effect as just raising the level of the existing expansion tank. Maybe I am missing something?
Graham is right, water does not need to flow through the header tank, it is just there to compensate for any expansion or contraction of the water due to temperature rise.
The problem with the original system was that the return of the coolant relied on vacume to suck the coolant back from the overlow (expansion) bottle which in most cases was not sufficient enough to replenish coolent into the system so air pockets were caused normally at the highest point in the system and with the stag this is the pump!
This is why all you have to do is ensure your tank is higher than the pump, so air is expelled into the header and not trapped in the pump and also have enough coolent in the tank to replenish the system when it cools.
Well as they say, there is more than one way to skin a cat
Gary
Originally posted by GTJones View PostGraham is right, water does not need to flow through the header tank, it is just there to compensate for any expansion or contraction of the water due to temperature rise.
Garynite nite all
Originally posted by Jeff View PostHi Graham,
You are correct in what you say but if the 'expansion' tank is fitted high enough, it also becomes a header tank.
My picture shows the height of the tank compared to the top hose and is the highest point it can be fitted.
This is all getting too complicated yet again and is quite a simple modification.
Jeff.
Peter, Cupar
CLASSICCHAV
Originally posted by peterrc View Postso as understand it all i have to do is raise the existing expansion tank, cut a hole in the bonnet to accommodate it and fit a scoop over the hole/expansion tank which will provide cooling to expansion tank and engine. Watch this space.
Peter, cuparjust drop the rv8 in now peter and save the aggro!
Originally posted by peterrc View PostSo as understand it all I have to do is raise the existing expansion tank, cut a hole in the bonnet to accommodate it and fit a scoop over the hole/expansion tank which will provide cooling to expansion tank and engine. Watch this space.
Peter, CuparI only do what the voices in my wife’s head tell me to do!
Whilst not essential, a flow and return system is desirable because:
1.Cooling system can be filled through the header tank. Without a return pipe there will be airlocks making filling difficult.
2.Allows additives (antifreeze, leak additive etc) to be put into the tank and mix properly.
3. Provides a path for trapped air to be expelled into the tank.
The top return pipe should not be too large though, or too much coolant will bypass the radiator.
So to go back to the original post!. With the original system there was a large pocket of air. You can compress air but not fluid. I assume the old system probably hardly ever reached 20psi? as it would just compress the air. With a header tank that is almost full it will compress the air and expell any excess water when it reaches 20psi and so find its own level, which is what Ihave done with mine. I would assume that this now means that overall it does run at a bit higher pressure? Just thinking out load really
Originally posted by V Mad View PostWhilst not essential, a flow and return system is desirable because:
Originally posted by jleyton View PostHi Graham - if you haven't yet gone to beddy buys - have you seen my earlier post in the joke section ?
Cheers and good night !
