Diamond back snake oil?
    Is this stuff for real?
    What is it and may it be the cause of that annoying rattle in years to come?
    http://www.ebay.co.uk/itm/STALE-PETR...b#ht_916wt_806
    treat it with the contempt it deserves.check the other stuff this seller has like the multispark thingy !!! absolute tosh...........................
    just keep the pedal down thatl negate any need for this product .it wont be in the tank long enough lol.
    steve
      It amazing what people will try to sell. It's no wonder I'm a sceptic.....
        I do have a magnet for my fuel though..... its called an engine! I cant stop the fuel racing through its throat!
          If you want multispark you need this http://www.msdignition.com/Products/...n-Control.aspx I have been using MSD ignition systems since the mid 70's when they first came over here. I run a 6AL on the production racing stag, they are excellent but not cheap.
            im familiar with these tony and they have good reports wherever fitted.excellence rarely is cheap,cheap is cheap in more ways than one the multispark device he is selling is only dividing what you already have no amplification and absolutely no gain..................
              I seem to remember someone on here dismanling a 'Multispark thingy' and finding nothing inside other than a couple of washers. - Possibly Russ (Kryten)?
              What is the advantage of using hte MAD Multispark thingamejig over 'nornal' electronic ignition systems?
                No, what happened was he accidently trod on it and it broke. And you are right, just a couple of washers inside!.
                How this thing works is like a placebo effect of sort,....after fitting this so called multi thingy you are suppose to change your plugs, points air filter etc,etc,etc.
                You are going to notice changes of course, BUT only due to replacing your whole fuel/ignition system to new!
                People are gullible they thing it's the Multi spark snake oil that is responsible for better running.
