Can anybody explain this:
ive got a MOD which has had an overhauled gearbox and an overhauled A type overdrive overdrive.
with the overdrive switched in when in 3rd gear and i then change up to 4 gear the gearbox always crunchs/graunchs its gears, but with overdrive out changing from 3 to 4th is smooth. Although the gearbox has been overhauled and synchros are unbeatable on downchanges i note that changing 2nd to 3rd (with the overdrive out )at low engine revs you can feel the gear cogs engaging / like its close to graunching also it very occosationally jumps out of third when coasting on zero throttle particualrly down long descents
Any ideas - its like the instant change of the A overdrive is beating the gearbox up sychros???
