Hi all, I require help from a budding auto sparky. My gear selector panel light does not work, changed bulb, no luck , their's power to one side of the fitting red wire, the other side of the fitting has a black wire coming from it that is connected to a red and blue wire, which seems to go off along the transmission tunnel towards the dash. If i unplug the black wire from the red&blue and touch it on the gear lever, the bulb lights, and i can record about 8.5volts, if i re-connect it and poke the volt meter down the connector i get 3.4volts?, think this must be a bad earth, but were do i look for it?.
looking at the haynes manual, it seems to be somewhere near or to do with the cigarette lighter?. Also looking at the wiring diagram the dash light rheostat seems to effect the panel brightness but what voltage is flat out, is it 8.5volts?, as all the dash lights seem dim (but nice)
Thanks for your help in advance.
