I'm about to replace my heads with 20 thou skimmed reconditioned units.
I've read the BLMC manual with it's recommended sequence of tightening 1 head, torquing the inlet manifold to both heads and then torquing the 2nd head
Then there is the view expressed by some on the SOC technical section that the heads should be torqued and the manifold made to fit.
Both seem logical but I have a question, If the V is 90 degrees and 20 thou has been shaved off the heads, should a like amount be removed from the inlet manifold/head interfaces to compensate.
HELP!!
HELP!!
