Hi All
As part of my unplanned carb overhaul I took the advice off the Forum and purchased a pair of Grose float valves from Moss. When I came to fit one in the first carb this evening it would not screw in more than one thread. I tried it in another carb body and the same thing happened. I then offered up one of the new standard needle valves supplied with the carb gasket kit and that screwed in fine. When I compare the Grose valve against the standard needle valve I am of the opinion that the thread has not been formed correctly.
Has anybody else come across this problem with Grose valves?
Bruce
Bruce
 hopefully at the weekend....
