Balancing.
    Balancing.
    Before I give up completely on these wheels, does anybody know where I can get them balanced on the car ? Preferably Midlands-ish. Martin.
    Originally posted by martin View Post
    Before I give up completely on these wheels, does anybody know where I can get them balanced on the car ? Martin.
    The Bonnet is probably large enough to fit them all on. The slope might make the balancing a bit tricky unless you have it parked slightly uphill?
      Any Good !
        Oooh Gray - you are a one M.
          Thanks Ian, but they're asking £60 for 2 wheels, cheaper than new wheels but I was hoping for something a little more competative. Martin.
            Couldnt resist it, especially when I knew someone would be along with a useful answer sometime soon.
              I hear what your saying mate, especially when you can have 4 done at Kiwk-Fit for £25. But in this day & age that's is not bad if you consider labour charges can often be over £100 PH and nearly £200 PH for the high end stuff. If £60 sorts it, it may be worth it, why not give them a call and see what they have to say.
                PM Sent
                  Just a thought , my car steering shudders when the front wheel bearings have a bit of play on them , Ive adjusted them several times over the years , Dont over tighten them !
                  Hope it works.
