As a long term Stag owner and SOC member it’s high time I contributed something back to fellow members via this forum. I’ll start by offering a description of my solution for a bullet-proof system for delivering fuel over the last 18 inches to the twin Strombergs. I don’t know if it’s original but hope someone might find it interesting/useful.
Like most owners I’ve installed various combinations of rubber fuel hose and jubilee clips to the carbs in that hostile environment just above the block. And like many before me I experienced various leaks and failures of said hoses. It was clear that any tubing of organic composition (rubber, synthetic polymer etc) was in for a tough time due to the high temperatures and strong degradation and solvent properties of the fuel (possibly even more so since the addition of ethanol). A short life expectancy and un-predictable hazardous failure seemed, and too often was, inevitable.
So, with access to parts scavenged from scrap equipment at work and some experimentation, I established it was feasible to assemble an all-metal system for the last 18 inches of fuel delivery. The breakthrough came when I found it was possible to mount a Swagelok compression fitting directly on the ¼ in OD brass fuel pipe stub exiting the side of the carbs thus eliminating the need for rubber/jubilee clips. From these ¼ to 1/8 reducing adaptors I added 1/8 OD stainless tubing to a Swagelok tee piece and from there finally out to a tubing adaptor where the line reverts to conventional fuel hose, well away from the hostile area (see the attached pictures).
The use of a piece of 1/8 tubing from the tee to the existing hose might be considered restrictive to fuel flow but it was all I had to hand from salvaged parts. In practice I don’t think it has ever proved a limitation.
This arrangement has indeed proven bullet-proof in the 5+ years since I installed it. All the joints can be repeatedly dismantled and re-made if necessary and this type of SS fitting and tubing is rated to 100s Bar pressure (way in excess of what is needed of course). Other owners could replicate this system if they wished, perhaps using brass instead of SS or using ¼ tubing rather than 1/8.
. IIRC the original factory system had a fixture off the cam cover?
