Circuit Breaker
    Circuit Breaker
    Through more luck than judgement I discovered a wire with the outer covering melted off in places and the bare wire showing.
    The location was behind the passenger parcel shelf and it was a wire (slate coloured) coming off one of the ignition relays on the circuit board. The cable should have been connected to a circuit breaker which prevents the electric window motors becoming overloaded. In my case the circuit breaker was missing and the cable was joined directly to the cable which would have been the output from the circuit breaker. If that was not bad enough the cables had been bared, twisted together and covered with some strange looking blue tape.
    This must have occurred a few years ago because the blue tape was now hanging off and when removed the two wires separated in my hand.
    It is possible that it was a temporary repair by a previous owner which got forgotten about and the melted cable was as bad as it would have got but needless to say a new circuit breaker will be ordered and the damaged wiring replaced.
    Of course what I don’t know is why the circuit breaker was removed in the first place but I am sure I will find out.
    Anyway, the reason for the post was to alert other owners to the possibility that their circuit breaker may have been bypassed and would be worth checking. I don’t know how reliable these circuit breakers are and it is even possible that as some point they were not available therefore to keep the electric windows working the failed breaker removed and the two wires joined together (hopefully more professionally than mine was).
    Phil
    You are not alone! - My stag had a 20 amp fuse instead of a circuit breaker. I only found out because the window switch developed an internal short and blew the fuse! Needless to say, it now has a new switch and a new circuit breaker and it is all working fine.
      Dave, you are were lucky you had a fuse, I am lucky I did not have a fire.
      Phil
        A scotch lock was my circuit breaker when I bought the car...
        I was going to ask, if the current on the circuit breaker is too much (from items drawing too much), will it kill it? I only ask as at £25 a pop, they're not cheap to replace (and I guess part of the reason why it was bodged on this car).
          The current is not enough to kill but the resulting damage may kill your bank balance,
          If you saw the melted cable on my car you would probably wonder why it dis not catch fire.
            I did have a series of fire hazards on my car when I aquired it (read the main positive power wire running with a cut cover in places place right on top of the engine block...)
            Still, gave me something to stay occupied with .
