Hi guys Stag running Rough Missing Plus intermitent backfire When warm, Coil seems HOT and Rev counter stopped working .Do you think coil chage good place to start Thanks Doug 2008
Back Firing Stag
Hi, On a recent long run here one of the guys driving a Stag with a 6 cylinder GMH engine installed starting getting very bad misfires when asking for power, even just going up hills.
Turned out that the fuel filter was blocked, changed the filter - problem solved!! Yes, I was dubious at first but it certainly fixed the problem. We zoomed home till my coil bombed - then my car woudl not start at all - no spark - new coil fixed that & it started first turn.
Good Luck Neil
Hi thanks for intrest Changed plugs now ok but rev counter gone awolNB Plugs had V burnt in centre electrodeOriginally posted by martin View PostHi Doug, the coil often gets hot to the touch, so that's no guide, try substitution, they're cheap enough. Is the backfire on the overrun ? Martin.
some plugs have the v formed in the electrode from new ,i assume its something to do with spark managment or other.......Originally posted by doug2008 View PostHi thanks for intrest Changed plugs now ok but rev counter gone awolNB Plugs had V burnt in centre electrodeBeautiful early mk1 white tv8 mod? MGB GT and now looking for another V8
