As this is a subject which turns up now and then with questions, I thought it might be of use to take a picture of the PDWA valve in the braking system. This valve is from a 1974 Mk2 Stag.
The "dumb-bell" steel part is the shuttle valve spindle, with two 'O' rings on it having been replaced. The repair kit comes with two large and two small 'O' rings. At least on my valve, it was the two large ones which were needed. The two small ones are discarded - maybe they are for a different valve or production year.
The switch with its brass plunger can be seen top right. As the shuttle valve is displaced due to a brake fluid leak on one side, the conical flank in the centre of the shuttle valve spindle depresses the brass plunger and this lights the warning light.
The blue tube is Ate Brake Grease which is safe to use for reassembly of components which come into contact with brake fluid.
The copper sealing washer on the shuttle valve blanking plug is also included as part of the overhaul kit.
The screw on the bottom left is a home-made tool from a filed down UNF bolt and which has the same basic dimensions as the switch. It screws in in place of the switch and keeps the shuttle valve spindle centred during brake bleeding operations.
Brake fluid is only outboard of the rubber 'O' rings on the shuttle valve spindle, so the switch can be removed without fluid loss or bleeding being necessary. If fluid dribbles out of the switch area, then this is an indication that the 'O' rings need replacing.
The nut and bolt with washers is simply the attaching bolt which fixes the PDWA valve to the inner wing - at least on a LHD Stag it does!
Happy PDWA overhauls!
