Aiton,
Read your article in the December mag and notice you run a Holley carb with a large dia. filter & you miss low down torque / power. I used to run with a 3.5RV8 with an Eddelbrock 4 barrel carb with the same type of filter and also seemed to suffer in the lower range rpm. The staff at RPI Engineering in Norfolk advised that the RV8 didn't like the volume of air that the filter allowed and suggested closing off some of the element.
This I tried using the old faithfull gaffer tape, working up to closing off about 75% of the filter. I certainly noticed a real improvement low down and no loss high up.
Don't know if this would be the same for the Stag V8 but it may be worth a shot.
Bye the Bye, what size is your Holley carb, my RV8 had a 600cfm. Holley when I bought it which was too big for the 3500RV8 so I changed to the 500cfm Eddelbrock which ran much smoother. Downside, the bores in my V8 were shot & it pumped out more oil through the old rope seal behind the flywheel better than the Torrey Canyon dumped in the Channel. New seals never lasted verry long so I changed to a 3.9RV8 with fuel injection before I got to the ultimate gaffer tape solution.
Regards,
Regards,
