"locking up the liquid gold"
    Hi all, another question, my petrol cap will not lock. key goes in, barrel turns nearly 180 deg but key cannot be removed ?, but when i look at the back can't see how it would work?, see photo,s, is there something missing?
    Cheers Guys
    The barrel mechanism is on a spring Pivot and yours is prabably seized up and needs WD40. Next time you meet another stag have a look and all will become clear. The key remains in the lock till it is relocked.
    Peter
      .[ATTACH=CONFIG]12536[/ATTACH][ATTACH=CONFIG]12537[/ATTACH][ATTACH=CONFIG]12538[/ATTACH] [ATTACH=CONFIG]12535[/ATTACH]
      Cheers Guys
      Dear M&M,
      Apart from Peters comments, You do have something missing. Its a diddy little peg that normally sits where you have circular crater in your piccies. It's right beside where the key protrudes through on the inside and turns with the key barrel. In your last piccy, it's at the 9 0'clock position on the key barrel. When the key is turned to lock the cap, it interferes with the wire that runs across the inside of the filler opening and stops the latch being pressed. It's a very flimsy arrangement at best and I fear it may have landed in the bottom of your tank.
      Hope that helps,
      Duncan, Skye.
        Cheers Guys
        Hello,
        I guess locking the petrol cap on a Stag is simply a very tricky job. With my Stag I hardly ever manage to lock it straight away.
        Kind regards,
        Dieter.
