Hello,
I am a new member to the SOC and hopefully fellow members will have some insight as to what the cause of my car's low oil pressure is. The original v8 has been rebuilt, new pistons, bearings, rods, valves, oil pump etc,etc. Tolerances all checked while assembling and within spec. ( did not check the jack shaft!)
Engine has good oil pressure at start up but as it warms up the pressure drops. When the engine is warm and at idle the oil pressure is 10-15 psi. While driving( warmed up) pressure is in the 30-50psi range.
Any advice is much appreciated.
Dave Q
Dave Q
