Hi Guys,
I have an early '73 manual with a 'A' type overdrive and the sump has two brackets spot welded on the sides and bolted back onto the rear engine plate. I presume this is some kind of anti-vibration device?
I decided to replace the sump as it has suffered impact damaged in the past and the drain plug has been cross threaded in the past by some moron!!
Obtaining a replacement (which is in great condition) from a usual stag parts supplier, this sump doesn’t have the side brackets.
Anyone knows if this is an issue if I simply remove the brackets on the engine rear plate and go without? Or will this bring on some kind of vibration issue?
Or should I transfer the brackets and spot weld them onto the replacement sump?
Postcript - According to parts listing its called a clutch housing extension Bracket/Strap and on the spec plate the car was an original manual with overdrive. (It shows the O after the LD production number)
