Need some advice around water pumps, I am currently replacing the head gaskets
and whilst I am at thought that I would check the condition of the water pump, the casing has the six vein water pump code on it, however on removal the water pump is a twelve vein type, so my question is, can you run a twelve vein water pump in a 6 vein casing without any issues, or should I replace the casing with a twelve vein casing.
Phil
and whilst I am at thought that I would check the condition of the water pump, the casing has the six vein water pump code on it, however on removal the water pump is a twelve vein type, so my question is, can you run a twelve vein water pump in a 6 vein casing without any issues, or should I replace the casing with a twelve vein casing.Cheers
Phil
