The system was doing fine then by mistake I loosened up the caliper joining bolts and thought since I did that i would replace the seals i had a spare caliper so I put in new seals and filled the system up. The brakes have been bleed now when i drive the car and you hit the brakes as in emergancy they seem to work fine but if you are stopping for traffic or a stop sign sort of slow stopping the pedal gets very harder to push. I got back to the garage and with the engine at idle depressing the brake pedal I can hear an air noise or vacuum noise down by the brake pedal up under the dash. Any ideas what this could be? am I looking at removing the booster ? Thanks in advance for your help.
Stuart
Stuart
